Old 04-05-2012, 09:18 AM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by Viperoni View Post
A more accurate way of saying it ;) and yes, we're agreeing to the same point.
Yes lol. There is a point to where it hurts, I have been to that point with an over sized turbo. I think the best power bands are the ones which hold a flat torque curve all the way to Redline, such as the f20 s2k motor and the 370z.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-05-2012, 07:37 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by 1.5Help View Post
Like I previously stated before you will need to stoke the motor as well to accomplish this 200-225hp goal. If you think otherwise you are mistaken.
If you need an example, just look at one of many Bisimotos N/A builds. If you need further guidance, talk to Brian Crower. Anyone that has ever done N/A racing will tell you the motor will need to be stroked. You are going for max output and on a motor of this size you will need to squeeze everything out of it.
This isn't going to be cheap and from what it looks like it appears to be a pipe dream.
Good luck to whoever pulls it off.
You seem pretty opinionated, Your ideas are right on but the construction of the 1nzfe is far from a typical modern Honda motor.
You have to realize that our 1nz fe has the same stroke as a k20 already using main caps which are not part of a girdle plus the caps are half the size. Our motors are already "stroker" motors, the bore to stroke ratio is already silly. I build motors, and have done stroker motors.... A stroker kit is really only beneficial for
a motor which is already efficient, the 1nzfe is not. If you put longer rods, that extra load on the crank ( from inreased rod movement, more leverage per say) will for sure crack the main caps if you try to rev it past 6300rpm... I for see this happening. 1nzfe is no F1 motor.
The motor is nothing but a pump to move air, stroking is one way to move more air but is not a good idea on our motor. The other way to move more air.... Spin that pump faster! Plain and simple. You want to make the 1nzfe more to the specs of a f1 or Hayabusa motor, produce air volume through efficiency with higher compression
and high lift cams... Then rev it out.
Ptuning.com
Old 04-06-2012, 01:23 AM   #3
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Wow, I got a big response from this, thanks everyone.
To answer a few of your questions, yes it would be expensive, but then again I see people dumping 10k or more into 15 year old Honda Civic's.
Why 200 HP? Well I think with 200 HP and with the weight of the Yaris it would give me a good power-to-weight ratio that I could take on the track, yet it wouldn't be total overkill, I mean don't get me wrong...if I end up with more then 200 after i'm done i'd be happy with it, but 200 is my goal.
I thought about going the 2zz route but I thought it would be too complicated, since I might have to cut the frame and modify the structure of the car to accommodate a different engine and transmission. I'm also worried about how much more weight the 2ZZ with a 6 speed would add to the Yaris.
I mean quite frankly...I would love a 2zz in my Yaris, and if that's the easier option I might end up going with that because i'd love to have a yaris with a 2zz.
I like engines with a long power curve that rev high, like the RX8 and AP1 S2k, and I wondered if I could do the same to my engine without making it completely unreliable. Bear in mind, this is all just a thought i'm pondering what might be the best route for something like this.
I have thought about a supercharged build, but then I wonder what kind of supercharger to go for.
Thanks for all your insight guys, I really appreciate it.
Black_griffin6 is offline   Reply With Quote
Old 04-06-2012, 12:46 PM   #4
Viperoni
Drives: 2005 Toyota Echo
Or curving upwards with a properly sized centrifugal supercharger
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Driven 2012 200 miles mr9865 Third Gen Yaris General Discussion 8 12-20-2011 01:03 AM
200 Unopened Hotwheel cars from early 2001-03? kustom play Items for Sale by private party 0 07-18-2009 11:58 PM
Video for Over 200 Km for my Yaris sedan 1.3L fezba Photo-Video-Media Gallery 11 06-27-2007 02:27 AM
tires for 200? nqd Off-topic / Other Cars / Everything else Discussions 2 06-18-2007 05:21 PM
