![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
It could be a bad tire. Rotate the tires and see if the noise changes location. It's a long shot, but doesn't cost anything to try.
Also, did you make sure the lug nuts were tight? If the tire shop didn't torque down the lug nuts, you might have a loose wheel that is vibrating. Very dangerous, but easy to fix. |
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 10:36 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 12:27 PM |
| Very loud noise from the engine | Stiv | DIY / Maintenance / Service | 27 | 10-27-2009 10:09 AM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
