Manual transmissions used to have oil change intervals every 30,000 miles. Im not sure what they are now but as I remember they are longer. I changed the oil in my ECHOs manual transmission at 30k but that probably not necessary. They also used to have an engine oil change at 600 miles but no longer. It was so cheap I did my ECHO at 600 miles.
Read your owners manual the intervals for the necessary maintenance is right in there. That is the bible. You definately do not need to be doing things more often than it says in the OM. If the dealer is telling you any different they are crooked. Before you do anything they recommend check back with us first!
| 50,000 mile Maintenance | Yari-Chan | DIY / Maintenance / Service | 9 | 04-10-2012 06:31 PM |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 09:00 PM |
| 60K Mile Maintenance | Pattycake | DIY / Maintenance / Service | 20 | 11-17-2009 02:34 PM |
| Why does 15000 service cost so much more than 5000 and 10000 mile service? | monyaris | DIY / Maintenance / Service | 7 | 06-25-2009 07:12 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 03:14 PM |
