Old 04-25-2012, 11:57 AM   #9
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
New info:
Battery is 4 1/2 yrs old :P ...didn't realize that at the start of all this, time flies
Guys at AutoZone say it is probably just an old battery that can't get it up any longer.
Voltage stays between 13.4 - 14.2 with or without audio stuff on.
Cooling fan ( that big white plastic fan right behind the grill ) does not seem to come on anymore. The maintenance required light is on... possibly low battery voltage or a result of the fan not coming on.
What triggers that fan? Engine temp?
Jumped the car off, ran it for about 10-15 minutes. Battery voltage is same as it was before jumping car. 8-9v. So it obviously did not charge any. I'm thinking the fan might have not come on because the engine was just cold.
I think I'll get a battery this evening but I'm afraid if something else is wrong then the battery will just slowly drain and I'll be right back where I was. :(
Any more ideas with this new info?
wsladaritz is offline   Reply With Quote
Trouble Code P2121 1nz DIY / Maintenance / Service 9 09-02-2024 07:59 AM
Alternator Trouble butter DIY / Maintenance / Service 1 08-10-2010 03:39 PM
Trying to find a H/O alt Slick In Car Entertainment + Electronics (audio / video / alarm) 11 09-16-2009 03:24 PM
Trouble Sleeping.... kac Off-topic / Other Cars / Everything else Discussions 27 08-23-2009 12:34 PM
Found a HO alt company plushDJ In Car Entertainment + Electronics (audio / video / alarm) 11 09-06-2007 06:06 PM
