Old 04-25-2012, 09:34 AM   #1
Chicken Little
Drives: 2007 Yaris
Embarassing Newbie question
I don't even know how to search this topic: 2007 hatchback, 90k, new standard Pirelli's. Old tires were crap Dunlops. Problem is that we have long stretches of cut pavement on the interstate loop around town due to snow/ice issues. When I hit these stretches, the rear of the car "hunts". It's quite noticeable, and is less than confidence inspiring. Goes away under acceleration. I had the suspension checked, and the tires rebalanced and rotated. What's up with this? Smooth pavement is no problem, marked improvement in traction and noise control with the new tires. Did not have this issue with the old cardboard Dunlops.
Chicken Little is offline   Reply With Quote
Old 04-25-2012, 09:49 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm assuming you mean the cuts run in the direction of travel? We have some similar areas on the highways near me, and I've had some strange wandering behavior as well at times. I just chalked it up to a mismatch between the tread and roadway. Could you post up a pic of your tread, or just the model so we could get a look at it?
Old 04-25-2012, 10:05 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
sometimes tires will just do that. It just means the tread somehow matches the grooves too much. Just slow down.
If it goes away under acceleration that means when you give the rear more traction the tires bite down and stick. If it really bothers you, you could throw a hundred pounds or so in the back, or get upgraded springs/shocks to hold the wheels and tires down more firmly.
Colin Chapman disciple
Old 04-25-2012, 11:34 AM   #4
^ or add a rear sway bar, or a trailing arm brace for stability back there.
Old 04-25-2012, 07:14 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
Know anyone who sells such equipment?
Old 04-25-2012, 08:46 PM   #6
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
So why are you embarassed?
12 yaris is offline   Reply With Quote
Old 04-25-2012, 10:06 PM   #7
Chicken Little
Drives: 2007 Yaris
I'm embarrassed because I bought a used Toyota that fishtails on cut pavement, spent $500 on tires to make it better, and my Dad is an engineer for General Motors.
Old 04-26-2012, 03:20 AM   #8
12 yaris
Could be worse,Your father could be employeed by Chrysler.
Old 04-26-2012, 10:52 PM   #9
Nicfin
Nic
Drives: 2008 3-Door Liftback Manual
As already recommended, a rear sway bar would probably help. So many have posted about how great they are, so I decided to take a chance and try one on my car. It definitely has reduced the floating sensation when driving, especially around curves. It may help in your situation as well.
Nicfin is offline   Reply With Quote
Old 04-27-2012, 01:05 AM   #10
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
It's the design of the suspension, particularly the geometry.
Took me three engineers, and lots of head-scratching, to figure that one out.
Old 04-28-2012, 09:30 AM   #11
Chicken Little
Drives: 2007 Yaris
Anti-sway it is, thank guys.
Old 05-09-2012, 07:21 PM   #12
Em_
Drives: 2007 Yaris
i LOLed
you guys don't need braces engineers or sway bars it's all about the tire tread
circular thread tends to follow the lines on the pavement
it's as simple as that
Em_ is offline   Reply With Quote
Old 05-09-2012, 09:26 PM   #13
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by Em_ View Post
i LOLed
Indeed, I found that tread design on the Yaris makes a huge difference when it comes to highway wander on both cut and smooth surfaces!
Old 02-10-2013, 07:32 PM   #14
andulong
andulong's Avatar
Drives: 2008 Hatch Red
Sorry to dig up an old thread but I was hoping for a recommendation for a good Yaris tire?
Thanks.
andulong is offline   Reply With Quote
Old 02-10-2013, 08:13 PM   #15
Nicfin
Nic
Thanks.
I put Michelin Defenders on mine a few months back. I believe they are 90,000 mile tires. So far, I cannot complain about them.
Old 02-12-2013, 11:17 PM   #16
why?
why?'s Avatar
Drives: Yaris LB
Thanks.
what are you looking for? Performance? Gas mileage? long life? That will decide which way to go.
Newbie Question on Acceleration soup1207 General Yaris / Vitz Discussion 8 07-26-2010 12:00 PM
Another newbie with another new Yaris Question sherriebythesea Wash, Wax, Detailing, Exterior Repairs 5 03-29-2010 03:05 AM
Yaris newbie question:) bonita! New YARIS Purchase Forum 2 08-19-2009 09:15 PM
Newbie question: installing new stereo nivanov In Car Entertainment + Electronics (audio / video / alarm) 11 04-08-2009 06:45 AM
Newbie ? lifthard1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-03-2007 11:47 PM
