Old 05-17-2012, 07:55 AM   #1
Originally Posted by sansag13 View Post
Hi,
Please let me know from where can I purchase ATF WS oil for yaris and how much costs usually?
Also, it you can let me know where to find drain and fill location of it, it would be really helpful.
Toyota dealer is really the only source, since only Toyota WS ATF is approved for use.
Here's the drain plug. You need a 10mm alllen wrench (or allen socket) to remove it. The fill location is the ATF dipstick tube.
Old 05-21-2012, 06:47 PM   #2
sansag13
Drives: 2009
Smile
Thank you Scott.. I am wondering how much used ATF comes out from this this drain plug. I was going through some forums and peopl say that just 1 quater oil will come from drain plug out for 3 quater. I am not sure how much correct this statement is for 2009 Yaris? It would be helpful if you can share your experiance with 2009 ATF change.
sansag13 is offline   Reply With Quote
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 08:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 05:01 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
