Old 06-06-2012, 08:21 PM   #2
You don't have it. If you did and the ABS fuse was pulled the ABS ECU, which is powered by the ECU-IG fuse would light up the ABS light. The 30A abs fuse is for the actuator, and the ECU-IG fuse is for the logic.
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 08:21 PM
ABS LIGHT & E BRAKE LIGHT rossman DIY / Maintenance / Service 5 02-25-2010 11:09 PM
Adding ABS to a Yaris tadc Performance Modifications 1 02-14-2010 03:56 PM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 09:12 AM
