play every day
That's cool, Garml!
We're running neck and neck. This is getting exciting. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
This is sick!!! Cant wait to see it :-)
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Im eggzited
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
play every day
Here's the flange as the grooves are being created so that the stock Oring gasket will fit right on.
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Excited to see this as well!
This is even better tooter :-)
play every day
The idea is to replicate the OEM design as close as possible, so that I can simply bolt it on without needing to make any alterations or adjustments to anything else.
The throttle body adaptor will be grooved in exactly the same manner so as to accept the stock Oring base gasket... |
play every day
Here's the flange with all of the OEM gasket detailing... groovy!
Drives: 1nz-fe Join Date: Jul 2012
Here you go all billet.
Right-hand side inlet, shorter turbo piping = faster spool up. And a 70mm Wilson Manifold T/B |
#10 | |
play every day
Mine are quite a bit more primitive... ![]() ![]() ...but on Tuesday I'll have this... to attach to this... ![]()
Only Happy When it Rains
just shakes head...
Tooter man you are crazy. can't wait to see what your final results are.
Colin Chapman disciple |
#12 | |
play every day
![]() I already have a pretty good idea how this will all shake out. Lose some bottom end for sure while maybe gaining a little bit at the top end. But since this is totally uncharted territory... no one knows yet how much of either so that's what I'm aiming to find out for myself.
Obsessed with 1.5L
i used to weld intake manifolds like whats on TBRs car, but for 2JZs & 2RZs...the head flange, runners & plenum baseplate had to be tightly placed/sammiched in a jig...3/8" thick steel plates on either side with 1/2" thick all thread bolted thru each runner.
With alternating welds on each runner, I would get virtually no warpage at all...requiring at most the slightest kiss on a belt sander to true it up of course with the 'rolla intake...you cant use a jig like that
play every day
We talked about the welding issues today...
...while the flange was being made... ![]() There's more pics and lots of video that I'll be uploading time permitting. |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
shinny
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
play every day
The flange and throttle body adaptor will both be ready to pick up on Thursday. (goody
)Here's a video of the CNC machine making the flange... http://www.youtube.com/watch?v=yVkFs7PlMVc This is so exciting to watch the part being made! Those numbers flowing down the lcd screen are the running stream of thousands of X and Y coordinates which locate the milling bit which is accurate to .0005 inch and can exert force of up to 2,000 pounds. The load graphs show minimal total spindle loading of about 3%. The part takes about 4 hours to manufacture. I'm going to try to get the parts to the welder as quickly as possible, and may have the manifold on the engine this weekend. Last edited by tooter; 07-18-2012 at 10:32 AM. |
^Your link is bad... It just brought me to my OWN youtube video page.
play every day
Try it now. The link is outside of my account.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
