Old 07-18-2012, 10:31 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Out of boredom....guessing game at gains??
Im feeling lucky...+4whp...wtq...-6peak
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-18-2012, 11:45 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey, we should have a pool!
My guess will be -6 hp at the bottom, and +2 at the top.
Old 07-19-2012, 01:02 PM   #3
malibuguy
Obsessed with 1.5L
well whats determining bottom? its less confusing guessing at peaks
Malibuguy: +4whp -6wtq
Tooter: +2whp
-96 Tercel 4dr
Old 07-19-2012, 06:02 PM   #4
tooter
play every day
tooter's Avatar
Tooter: +2whp
Yes, that's much simpler.
So far we have
Malibuguy +4
Tooter +2
Garm -5
Mazilla +1000
Mazilla, make another guess.
That one has really long odds.
Old 07-19-2012, 02:08 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Put me down for + 1,000 whp...I believe in you!
-Type 07 FFL-
My odometer 03/11
Old 07-19-2012, 02:10 PM   #6
Garm: -5 whp / -5 torque
Bonus for the CEL?
Shall MI donate the prize for the pool?
Old 07-19-2012, 05:59 PM   #7
tooter
play every day
tooter's Avatar
How about something like 5% off any one purchased item as a prize. Then it's just a little bit less profit rather than an out of pocket expense.
Old 07-19-2012, 11:57 PM   #8
tooter
play every day
tooter's Avatar
Oh oh, Garm...
Maybe you already know something that everyone else here doesn't know from having worked on your manifolds for years. It's highly likely that you have the most realistic guess!
Bonus for the CEL?
Oh oh again... maybe you already know about that, too. Have your manifolds triggered CEL's?
Old 07-19-2012, 06:10 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
+/- 2-6%
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 07-19-2012, 06:24 PM   #10
tooter
play every day
tooter's Avatar
Originally Posted by Golddeenoh View Post
+/- 2-6%
Hey Gold... you just covered everyone else's guess.
Pick just one number and one plus or minus sign. ;)
Old 07-20-2012, 12:51 PM   #11
Golddeenoh
Golddeenoh's Avatar
fine +5% hp gain and +3% torque
Old 07-19-2012, 06:14 PM   #12
anomoly40
Depot Damager
Drives: '08 Liftback
+1hp -3 tq
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 07-19-2012, 06:25 PM   #13
tooter
play every day
tooter's Avatar
Originally Posted by anomoly40 View Post
+1hp -3 tq
Ok... anomaly is down for +1hp.
Old 07-19-2012, 10:53 PM   #14
tooter, everyone is picking a number for whp, and a number for torque -- can we keep it in that format, please?
and yes, 5% on one item works for me. I'll make up a coupon for the winner of the pool.
Old 07-19-2012, 11:03 PM   #15
tooter
play every day
tooter's Avatar
Certainly, Garm.
I just thought that it might be a lot more simple with each guessing just one horsepower number. We can do it any way you want since you're providing the prize.
We could combine the total of how many horsepower and torque numbers each guess is off, and whoever is the least total amount off is the winner.
Old 07-19-2012, 11:07 PM   #16
tooter
play every day
tooter's Avatar
I got some PICTURES...
Roger and Bill made this beautiful part.
Their business is called:
Origin Designs
http://origindr.com/
The stock gasket drops right in and fits like a dream...
It took some filing to get the runners to fit as they are not all uniform. But the flange is on tight enough to weld. You can see on the inside the edges that need to be feathered out after it's welded up.
Ready to go to the welder...
Old 07-20-2012, 01:18 AM   #17
ljming99
Drives: Yaris '06
Given the long runners, and my limited knowledge of VGIS used in chevy cars.
Im guessing probably ~ +3% torque and a ~ -3% decrease in top hp assuming that vvti doesnt do something funny =P
""VGIS stands for Variable Geometry Intake System. In this system, the length of the intake manifold is varied according to the rpm of the engine. (using a set of flaps that are automatically activated, maybe).
"To provide a smooth power delivery and torque across all engine speeds, the air intake system needs to be narrow and long at low rpm and short and wide at high rpm. Since these are conflicting requirements, most inlet systems are a compromise between low and high rpm performance. Varying the inlet tract gives the best of both worlds and variable intake systems in which the inlet tract length varies depending on the rpm is now increasingly common in many cars.
The Optra 1.6’s Variable Geometry Intake System (VGIS) uses a valve to alter the length of the air intake tract, making it longer when the engine is running low revs and shortening the path of air when the engine is running at higher rpm. This improves throttle response and offers a flatter torque curve and is the main reason for the Optra 1.6’s good driveability.""
ljming99 is offline   Reply With Quote
Old 07-20-2012, 01:28 AM   #18
tooter
play every day
tooter's Avatar
The Corolla runners are actually a little shorter and fatter than the stock Yaris manifold...
You can't see the full length of the stock runners without removing the manifold and looking at the bottom, because they wrap almost all the way around the plenum like a snail shell.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
