Old 07-20-2012, 11:12 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hp and tq is fine since everyone is already guessing both.
Old 07-20-2012, 11:49 AM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
wow that looks cool
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-20-2012, 12:52 PM   #3
By the way, I can't win, if my guess is the closest, next best guess wins.
No one is going to say this thing might blow 15 extra horsepower? Woosies!!
Old 07-20-2012, 12:59 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
wouldn't there need to be a greater balance of intake to exhaust to be able to even possibly gain that much more, i.e. a large diameter mid-pipe to ensure higher out flow with the increased inflow.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 07-20-2012, 11:18 PM   #5
tooter
play every day
tooter's Avatar
Goliath guessed that this manifold might blow.
Old 07-20-2012, 01:01 PM   #6
^ Of course, but we're just having fun guessing right? If you saw my guess, you'd know I was kidding.
Old 07-20-2012, 06:07 PM   #7
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
zero change
goliath1812 is offline   Reply With Quote
Old 07-20-2012, 06:27 PM   #8
tooter
play every day
tooter's Avatar
That may be the safest guess of all...
Since torque numbers are also being included, and I guessed +2hp at peak, I think the torque will be -3 since the runners are shorter and larger in diameter. The manifold might have greater usefulness with forced induction rather than in a normally aspirated application. It can easily handle being pressurized. I saw the throttle body adaptor. They're machining a smooth transition between the smaller bore diameter of the throttle body and the larger diameter of the manifold inlet.
Old 07-20-2012, 06:30 PM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I think I'll go with +4hp and slightly reduced torque. I'd love for Golddeenoh's (or even mazilla's) guesses to be correct instead!
Old 07-20-2012, 06:40 PM   #10
^ tooter needs two numbers from ya, tk
Old 07-21-2012, 12:56 AM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I'll go with +4whp and -3% torque...
What can I say? I'm an optimist. Plus I'm shooting for a somewhat similar setup myself.
Last edited by tk-421; 07-21-2012 at 01:14 AM. Reason: **slams head repeatedly on wall**
Old 07-21-2012, 12:59 AM   #12
LOL, tooter you are so cool.
tk, I meant a whp and a torque number, both peak. That is the format for guessing.
Old 07-21-2012, 01:35 AM   #13
tooter
play every day
tooter's Avatar
I know... I just can't pass up an opportunity to fool around.
Old 07-21-2012, 01:16 AM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Fixed!
Old 07-21-2012, 10:09 AM   #15
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I am soooo chompin' at the bit over this one.
I just want to see it on the car and on the dyno (along with numbers).
the mock up you have with the intake and the flange looks good.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 07-21-2012, 10:22 AM   #16
tooter
play every day
tooter's Avatar
I've been test fitting the prototype flange to the engine...
There are a couple of areas that need to be filed to fit because we went 3mm larger on the perimeter to accomodate the larger runners. There's one more spot to file near the middle of the fuel rail, so I should have it on today, and when the fitting is done I'll be sure to post some more pics. Wait till you see it with the runners on... it's gnarly.
Old 07-21-2012, 12:02 PM   #17
tooter
play every day
tooter's Avatar
I just set on the runners to check the clearances... (goody )
Looks really neato.
Old 07-21-2012, 12:10 PM   #18
anomoly40
Depot Damager
Drives: '08 Liftback
You plan on wrapping them?
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
