Old 06-08-2012, 11:14 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Excellent ideas worth considering, guys!
On the flaring idea. maybe just right at the end so that it would be covered up by the weld and wouldn't even show. Pulling the outer runners together might also work if I used two parallel pipes the exact diameter as the inside edge of the runners. 5mm on each isn't much. I might try putting just a little pressure on them to see exactly how much resistance there is. And maybe a combination of both... of just a bit of pulling and a touch of flaring.
It's really great that the slight misalignment issue the only thing close to an obstacle. The engine flange and adaptor plate for the throttle body are pretty academic. A thick throttle body plate will have 3 counter sunk recesses to accept short hex bolts which will attach it to the manifold, and then have 4 threaded holes for the stock throttle body studs. I should be getting the stock manifold soon which will be used for the pattern to keep everything oriented as close to their stock positions as possible.
Old 06-08-2012, 12:43 PM   #2
^ It is possible to speed up the air traveling through an opening fixed in size, if the previous manifold isn't optimized for air flow.
Old 06-08-2012, 04:02 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Old 06-08-2012, 04:24 PM   #4
tooter
play every day
tooter's Avatar
Yes. And I'm figuring that the air flow of the stock manifold is very well optimized for efficiency and driveability in the lower rpm ranges.
It would be difficult to beat that because once they start with computer simulations and molding plastic intakes it's perfectly feasible to form them into any configuration without limitation.
Even though the Corolla manifold is made to supply an engine which is 20% larger than the Yaris, it's highly unlikely that it would flow any better under normal everyday driving conditions.
The only advantage I can see (besides it looking really cool ) is the runners being in direct line with the axis of the throttle body.
It's strange how that tube extends straight out from behind the TB and into the plenum...
It's 2 1/2 inches long and terminates 2 1/2 inches away from the runner intakes. There may be some harmonic flow principle behind making those two measurements equal, because you'd normally think they'd simply make the throttle body dump straight into the open plenum.
All this stuff positively fascinates me, and it's no end of fun to explore.
Old 06-08-2012, 04:04 PM   #5
Old 06-08-2012, 05:07 PM   #6
fnkngrv
fnkngrv's Avatar
making fun of the couple companies out there that claim what they do about much better airflow with those tornado gadgets.
Old 06-08-2012, 04:57 PM   #7
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I would get a drimal and clean up that corrosion^ maybe smooth it out a little.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 06-08-2012, 07:49 PM   #8
tooter
play every day
tooter's Avatar
The black is just accumulated layers of unburnt hydrocarbons that repeatedly got cooked over the many years of the manifold's life. I'll be spraying the whole insides with engine degreaser and hosing it out. Can't get inside there with a Dremel. The hole is way too small and the runners are too deep inside the plenum.
Old 06-10-2012, 11:20 AM   #9
tooter
play every day
tooter's Avatar
Saw this pic of a thick custom made intake flange on the Micro forum...
I tried tapping with ball peen hammer on the inside of the runner to flare the opening with some success. But instead of risking denting or deforming the runners, a thick flange like this one with a few extra beads of weld on the misaligned areas will provide plenty of room to smooth the transition from the inside with a grinder between the runners and the engine intakes.
Old 06-08-2012, 07:19 PM   #10
oh yeah those things... lol
Old 06-10-2012, 01:07 PM   #11
Golddeenoh
Golddeenoh's Avatar
^ I need one of those to go with my prius pistons :D
Old 06-10-2012, 09:23 PM   #12
tooter
play every day
tooter's Avatar
That's beautiful for a scratch built manifold. It says: Go Fast.
While I'm still waiting to receive the stock manifold before the project can proceed, I did manage to clean up the insides of the manifold...
...with a combination of engine degreaser and brake cleaner. Just a personal peeve, I can't stand working with dirty parts.
Old 06-11-2012, 08:12 PM   #13
tooter
play every day
tooter's Avatar
Just got the stock manifold today in absolutely pristine condition.
Thanks, 90tsi for selling me yours.
Now there's an accurate frame of reference for clearances, throttle body stud spacing and such. Next up is a trip to the machine shop.
Old 06-11-2012, 08:38 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Would you be willing to share those numbers? I'd be happy to put them on to the CAD drawing and re-post it. Oh, I already have the throttle body template sketched. Now where did that one go... Aah, there it is. The bolt pattern is identical to the 1.5L TB, but the bore is smaller (on the 1.5L).
Old 06-12-2012, 01:16 AM   #15
tooter
play every day
tooter's Avatar
Sure, Cranky...
Which measurements would you like?
The Yaris manifold bore is 48mm whereas the Corolla is 50mm.
Old 06-11-2012, 08:19 PM   #16
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
where did you took the corolla intake manifold ?
Interior:ALL red, black roof
Old 06-11-2012, 08:43 PM   #17
tooter
play every day
tooter's Avatar
Bought it on Ebay.
They're pretty common as toyota used them for years on a couple different models.
Old 06-12-2012, 06:30 AM   #18
CrankyOldMan
Doh, I should have been more specific, eh? The bolt pattern for the head-side of the intake. I made some educated guesses on my CAD model, but haven't actually measured them.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
