Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
looks like your "j" and "t" made a baby or you put the lower case "t" backwards :D
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
play every day
#3 | |
The font for this forum is a sans serif font (verdana/helvetica/arial) where this is no crossing at all or "half crossed". Helvetica J: ![]() Times New Roman J:
2ZR swap. DO IT! Ask how!
Augh! He said serif!!
I agree about the catchy logo idea though, and can appreciate the effort to use simple shapes for easier manual G-code. |
#5 | |
play every day
![]() 2 full circles oo 2 semi circles, each with a + at one end 1 3/4 circle with a horizontal _ 1 semi circle with a vertical l |
play every day
Picked up all the pieces from the CNC machine shop today...
![]() ![]() ![]() ![]() ![]() ![]() Cranky... you can see the the areas on the inside of the outer runners that will be undercut with a hand file to the line scribed by the machine that matches the Yaris intake ports on the head. The solution was so simple. ![]() ![]() Next up is an installation clearance test of everything including test fitting the throttle body... ...and then it's off to the welder.
Lookin good :)
slap that shit in the car!
play every day
One step at a time...
What's sealing the adapter for the TB to the manifold?
play every day
A stock Corolla throttle body gasket seals the adaptor to the manifold...
It's a thin stiff metal sheet with rubberized coating on both sides. All of the gaskets used are OEM. ![]() Those three black allen bolts holding the adaptor to the manifold are screwed into the original threaded Corolla throttle body mounting holes. |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I can't wait to see what this does on a dyno. So close!
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Damn damn damn hurry up!!! ;)
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
So is this thing going to be a "shower" or a "grower"?
If you want to enjoy your car, stay off of the internet. |
play every day
Far more likely to be a "shower".
![]() Remember that the Toyota engineers could model the plastic intake manifold in absolutely any shape, so I'm certain that what they came up with was the best for overall driveability. Now that all the parts are back home, I just took a cloth measuring tape to the runners of both manifolds and am suprised to discover that the runners are just slightly longer than the stock Yaris runners! ![]() Yaris runners, end to end: 19" Tooter runners, end to end: 20" Just by looking at both, Dang! I would have sworn that the Corolla's were a lot shorter! It was the larger diameter that only made them appear that way. This bodes well for low end performance, although I still believe that low end torque will suffer somewhat because larger diameter runners means slower air velocity at low rpms. Now how much low end loss is an open question which will be settled on the dyno. ![]() Here's a pic of the inside of the stock manifold... ![]() You can see the entrance to the first runner at the bottom which is at 90 degrees to the manifold's intake, and the plenum is quite large. In contrast, these runners are all pointing directly at the manifold's intake and are all the same short distance from it... ![]() I believe that this manifold would really shine under a forced induction situation. First, because it it is plenty strong to take being pressurized, and second, it can handle 20% more air flow under equal conditions because it was made for an engine with 20% more displacement. Last edited by tooter; 07-27-2012 at 09:40 PM. |
Did you think of maybe running a Corolla TB on it later on down the road?
play every day
I thought I read a thread where people were using a corolla TB with no wiring/ecu issues. Plug and play. Why not go that route? My plan is to buy another stock intake manifold and port match it to a corolla TB.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
