play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I believe it was specifically manufactured that way so that just one MAF tube would be able to fit both the 1NZ and 1ZZ throttle bodies.
Pretty clever idea, actually.
#2 | |
play every day
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
My memory is probably quite bad, not sure if the original tubing is hugging the battery.
Any issues there? i see from the picture that the grey tubing is up against the battery. |
play every day
The tubing touches the corner of the battery because the tooter manifold relocates the throttle body a couple of inches to the right. However, it doesn't cause any problems as there isn't enough pressure on the corner to kink the tubing.
play every day
The first run of redesigned adaptors is done. The advantage of these are that just one part works for both the 48mm 1NZ FE throttle bodies and the larger 51mm 1ZZ FE throttle bodies...
![]() ![]() There was a clearance issue with one of the hex head bolts and the larger diameter throttle body gasket. The solution was to simply reduce the diameter of the head with a grinder... ![]() The larger 1ZZ FE gasket fits perfectly. Just finished bead blasting, and it's ready to install on a manifold. ![]()
2ZR swap. DO IT! Ask how!
Again with the car pr0n! Looks great, too!
Have you done a test fit yet to make sure the 1NZ TB seals properly on the car running?
#8 | |
play every day
The 3mm larger diameter O ring gasket means a perimeter radius difference of only 1.5mm larger all the way around which isn't a lot. ![]() The 1NZ FE throttle body base has a much larger flat area on it's base than that. I'll be running a new adaptor this coming week to confirm that everything works. |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I'm very interested to see if this makes power with the 1zz throttle body, which it should.
Keep up the good work! |
play every day
One tooter manifold with the redesigned adaptor adapter is now complete...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Now just one 51mm bore adaptor plate fits both the 1NZ FE and 1ZZ FE throttle bodies. The tooter uses all of the stock Toyota head bolts, studs, and nuts, and the stock Toyota O ring manifold gasket. It uses a Toyota 1ZZ FE throttle body O ring gasket which works fine with the smaller 1NZ FE throttle body, and uses all of the stock throttle body studs, nuts, and bolt. The manifold flange is hand clearanced fit to the head perfectly and simply drops right in. Not too bad for a wrecked dirty 14 year old junkyard part. ![]() It requires the intake to be shortened because the throttle body is repositioned about 2 inches to your right as you're looking at the engine from the front of the car. Last edited by tooter; 11-13-2012 at 12:02 AM. |
Looks great! When is dyno day?
play every day
Soon... :)
Whenever I can find some time off from work. Lately, I've been swamped. This time it's going to be back to back runs on the same day to get an apples to apples comparison. I still need to work on adapting the BLOX velocity stack intake to eliminate the 90 degree bend while still fitting in the available space. I already have the new design down, and the raw materials have arrived, but I still need to find the time to cut and fit everything together. |
Are you using a 1ZZ throttle body now for everyday driving? How's that working out?
#14 |
play every day
#15 |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Can't believe I had missed this thread. Awesome job Tooter. I have a Weapon R intake manifold, and a Gude bored out T/B if ya want to add it to your dyno test pulls. :) Probably going to have to purchase the DIY kit from you seeing as how I have a 1ZZ manifold laying around....and a turbo waiting to go onto that. Would be interesting to once and for all "expose" what some of these parts do. Thanks to all for the great read!
#16 | |
play every day
I'm going to be doing back to back stock manifold/tooter dyno runs on the same day this coming week if I can get off of work. The tooter Do-It-Yourself kits are available for $250 +$12 shipping. ![]() ...and you can build your own. ![]() ![]() If you are interested you can either PM me here, or call 310-455-3340, or email me at: greggabi@verizon.net Last edited by tooter; 11-17-2012 at 01:53 PM. |
#17 |
Doh! Realized after I re-read what I posted that I didn't mean to sound like I was trying to dump testing costs on you....sorry. When I get back from this tour I'll touch base with you on the purchase. I can gear up on my end and test both manifolds with/and without turbo. My personal taste is gonna be polishing that beast. Thanks again for some great brain food!
Greetings from a place in the world where everyone hates us. :) |
#18 | |
play every day
![]() Didn't know you're in the Military. I did a tour in 'nam so I know what it's like. Keep safe and come home in one piece. Polished would look super. With those shiny pipes snaking around, your engine will look like a formula 1 racer. ![]() Take Care, Greg |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
