play every day
Now that's an intriguing idea.
![]() Does anyone here run a throttle controller that they can program for instant deceleration? |
2ZR swap. DO IT! Ask how!
From what I remember reading in other TB swap threads, you need to let the ECU completely reset between idle screw adjustments--i.e. unplug the battery for at least a few minutes. In theory, that will help with the idle RPM hunting.
Tooter has a 2012, which has an entirely new ECM, so there may be some differences in how the ECM reacts to changing the throttle controller.
play every day
I'll still try Cranky's advice (Thanks!
) of resetting between each idle change. I'm really going to crank it down today, because regardless of any of the other issues, it idles too fast. I was thinking that maybe the ECU keeps fishing around for the right idle speed, because the butterfly is prevented from closing enough to acheive it.
I don't remember if it was asked at all, but does this manifold sit any closer to the rad than the plastic one?
#6 | |
play every day
play every day
It was the IDLE.
![]() This morning, I cranked the screw out one full turn and did a cold start. Didn't even reset the ECU. NO CEL light. Totally normal start. No racing idle. No hunting for idle speed. Perfectly normal warm up idle. Totally normal hot idle. No surging. No sudden shuddering notch from slight throttle to decel... ...and the throttle response is SUPERB. (oooh, goody )So the problem was that the ECU couldn't function properly because the butterfly was being physically prevented from being closed enough by the idle screw which was factory set for a 1.8 and not a 1.5. I can't tell you how happy this makes me to have found out how to instantly solve all of the problems with just one simple procedure. It was really dicey breaking loose the idle adjustment screw without stripping it. I used a fractional inch hex key as it was slightly larger than the metric one, and applied Liquid wrench to the threads. Then I put in the hex key and tapped it with a mallot. It turned really hard right at first and then was much easier as the oil penetrated the threads. Now it twiddles without being loose. I'm going to set it with silicone so that if I ever need to readjust it, the silicone plug can be removed easily. Dyno shop, here I come!
#8 | |
play every day
play every day
I combined the Simota intake tube with the BLOX velocity stack because the Simota is larger in diameter which matches the larger diameter of the Corolla throttle body throat...
![]() Now no adaptor coupling is needed, as everything is all the same size straight through from the velocity stack to the throttle body... ![]() ![]() Notice the throttle body?... you'd never know that was an 8 year old junkyard part. Stainless steel micro bead blasting makes the old casting look like it's brand new. I think I'll go for a ride now.
![]() Drives: 02 Yaris 1.5 T-sport Join Date: Dec 2012
Glad to hear you got it running sweet!
cant wait for the dyno!
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
That's awesome you got it all straightened out. I wanted to adjust the idle screw on mine, but it didn't bother me enough to go out of my way to take the time to do it. Now I kind of wish I had...however, I agree, the throttle response is AMAZING! My fiance, who used to have a Yaris, even commented on the difference it makes!
Can't wait to see what the dyno puts down for you!
#14 | ||
play every day
![]() I can't believe that it works so much better than the stock throttle body. Especially in low rpm response. You barely touch the pedal and the car is right up to speed. Haven't taken it on the freeway yet, but I'll do that tomorrow. It's all gassed up and ready to take mileage readings. Quote:
![]() Now the 1.8 throttle body matches the 1.8 manifold as well as the oversized SRI. |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Ya, I get snickered at often over at the PriusChat - buncha eco modders.. But its my car, I'll do what i want. I read up on the Bonneville Salt Flats Prius
![]() When they set the 'record' in the G2 Prius, they did it by swapping the 1NZ-FXE for the 1.5L 1NZ-FE otto cycle motor swap from echo, modified the intake routing (but used the 1NZ-FXE intake manifold - no room for the 1NZ-FE manifold because of the Invertor and MG1&MG2 configuration under the hood), JDM TRD ECU, inverter upgrade (550V from 500V), final gear changes, transmission cooling system, custom 1-off suspension, larger front diameter tires and custom exhaust. |
#16 | |
What was the record, and how long was the course?
#17 | |||
http://www.theautochannel.com/news/2...21/308572.html This was all done in 2004... so prob not much of a record anymore. Jetta set one this past year at 186mph but using a 1.4L with a turbo. Class - H/PS. The class is for production cars with engines of less than 1.5 liters that use forced induction. So not in the same class as the Prius... Quote:
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
