play every day
Sorry, no flowbench... but I am going to dyno the experimental manifold, so a few runs will show if there's actually any improvement. If not, I'll simply cut off the plenum and try something else as I also have another even more strange idea I'd like to try out if this one doesn't work.
Pure R & D is fun.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
smooth it out then make it Phallic for Garm. for some reason that now makes sense...
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I love following this thread. Keep up the good work!
play every day
Thanks, man...
![]() This whole adventure has been no end of fun and it's not over yet. Ideas are always connected to other ideas, so it's simply a matter of implementing one idea to see if it works... and if it does, choosing another idea to implement from the other ideas which are connected to the first idea. I'm also fascinated with "microbusiness". A microbusiness has all of the qualities of a large corporation, except it operates on a very small scale. First you come up with an idea, then you design the concept, then manufacture a saleable product, then use the proceeds to buy the freedom to do the research and development to explore other ideas. ![]() A microbusiness has one huge advantage over a large corporation. Just one person exercises complete control over the whole process from concept, to design, to finished product. So all that's necessary is for one person to have a clear vision of what they wish to accomplish, and to simply be motivated by their own curiousity to explore the possibilities. I believe that everyone should enjoy the fun of becoming an enterpreneur by cultivating their own microbusiness... something in which they are genuinely interested, and which can be implemented on a small enough scale that they can do it "on the side". |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
The American dream of being your own boss.
Look forward to the dyno runs. Would be interesting to see a turbo dyno run comparison also. Once I get this employment situation under control, I'm gonna have to catch you for one of those flanges to go with my intake.
Why strive for a JDM BB, when you can promote the Scion badge? |
#6 | |
play every day
Once you get a taste of piloting your own little boat... you never go back to pulling an oar down in the hull of someone else's ship.
![]() Quote:
I think that the Corolla manifold would excel in a forced induction situation simply because it's so much less restrictive than the stock manifold. |
play every day
Met with the CNC guys today and the 1ZZ throttle body base plate is in the works.
We came up with a simple practical design that will fulfill two purposes. The first purpose is of course the tooter e. t. manifold. And the second purpose is to make it possible to install a larger 55mm 1ZZ throttle body onto a Blitz supercharger. Installation would involve cutting off the existing 1NZ 46mm flange with a hack saw, and welding on the 1ZZ 55mm throttle body base plate which will work for both the 46mm and 55mm throttle bodies. The smaller entrance to the SC would need to be flared out with a file or a Dremel to smoothly transition to the larger bore of the base plate. The combination throttle body base plate/bellmouth will be 2 inches thick, with the top inch being the square 4 threaded stud base with the O ring gasket groove just like the original tooter adapter plate... ![]() The bottom one inch will be a continuation of the 55mm diameter throat smoothly terminating at a rounded bellmouth profile similar to these... ![]() ...except that the outside diameter of the mouth will be exactly the same as the outside diameter of the intake. This combination base plate/bellmouth could be also easily be attached to any custom fabricated plenum if someone was building their own custom intake manifold from scratch. I'm only having one extra made as I have no idea if there is any interest in this new product. It'll be $165 including shipping, so let me know now if anyone wants dibs on it.
play every day
Thanks for posting that, Viper. RacerX has some very clever ideas.
Notice the first manifold is the stock cast MR2 runners with their own custom plenum design attached to them And note the V8 Mustang throttle body base plate bore. It must be 80mm! ![]() ![]() The straight runners are so long on the last manifold it's a cold air plenum because it's located in the trunk. ![]() ![]() I've found a few others doing the same thing while searching the internet for manifold inspiration. Every other manufacturer I've seen starts with a basic one inch CNC baseplate as the foundation for their designs. That's the beauty of aluminium. It's cheap, light, and easy to machine and to weld. |
As long as the MAF is in a tube the same size as stock, it doesn't make any difference what size the pipe is on either side of it.
toot toot!
The Enterprise D
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Sure looks fun. You have your own CNC machine?
2ZR swap. DO IT! Ask how!
play every day
Right now they're cutting the bellmouths on the back sides of the throttle body bases. They're like beautiful works of art...
#16 | |
play every day
play every day
I pick up the parts this afternoon. The second throttle body base will be done then.
![]() ![]() This is my inspiration for the design... http://www.youtube.com/watch?v=DGH6cm0XsTg If it works one way... it'll work the other way.
play every day
They turned out beautifully...
![]() ![]() ![]() This throttle body base plate also has a secondary function in that it makes it easy to install a 1ZZ throttle body onto any 1NZ supercharger. Just cut off the old baseplate with a hacksaw, flare out the end of the supercharger's intake with a grinder, and weld this one onto the intake. ![]() ![]() This is a mockup of the et manifold layout...
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
