Old 08-14-2013, 09:14 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I cut about half of the bend off of the slilcone coupling to straighten the intake because the air filter didn't need that much bend. So it's all ready to run...
Just called Harry...
...dyno test is on for Saturday.
Old 08-14-2013, 10:03 PM   #2
Cool!
Old 08-14-2013, 10:26 PM   #3
tooter
play every day
tooter's Avatar
...and the Tacoma hits the dyno next week if I can find the free time.
I already did the baseline dyno, so the next one will be with the tooter II.VII.
Old 08-15-2013, 07:15 PM   #4
Viperoni
Drives: 2005 Toyota Echo
Sweet!
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 08-17-2013, 05:41 PM   #5
tooter
play every day
tooter's Avatar
On the dyno, the tooter et didn't perform any better than the regular tooter, but it didn't perform any worse either. With 111hp and 105tq the graphs are basically the same. So for all my tinkering around, I didn't actually change anything!
Old 08-17-2013, 06:53 PM   #6
etherdude
Drives: 2012 Yaris SE 5-speed
thanks for the data...
Tooter, please remind us. How do your fully modded figures compare with "bone stock"?
Thanks, Doug
etherdude is offline   Reply With Quote
Old 08-17-2013, 07:38 PM   #7
tooter
play every day
tooter's Avatar
Thanks, Doug
Here's bone stock dyno runs from the dyno chart sticky thread:
The results.
Stock:
91hp
91tq
Tooter:
111hp
105tq
So with:
Intake
Throttle body
Intake manifold
Header
Axle back exhaust
I have 22% more horsepower, and 15% more torque with the stock ECU, no tuning, and regular 87 octane pump gas. Latest gasoline fillup today: 39.4 mpg.
Total cost: $1,350
Old 08-18-2013, 11:17 AM   #8
tooter
play every day
tooter's Avatar
I'd also add that none of these modifications has altered the basic reliability economy or longevity of the engine. My wife's car is still just a regular daily driver that always needs to be in service.
Now it's just way more fun to drive...
Old 08-19-2013, 02:07 AM   #9
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
So with:
Intake
Throttle body
Intake manifold
Header
Axle back exhaust
Total cost: $1,350
That's impressive considering you haven't modified any electronics and let the stock ECU make any corrections.
Tooter, I really plan on coming up in the next 2 wks or so. I'd like to meet up and talk with you about my ideas for my 1NZ-FXE. It includes a few items like the ones below...
JustDidIt is offline   Reply With Quote
Old 08-17-2013, 07:13 PM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
While it's disappointing to see that there isn't an appreciable improvement, it's certainly unique. Have you considered changing the runner length on a "standard" tooter for comparison?
Old 08-19-2013, 02:06 AM   #11
tooter
play every day
tooter's Avatar
The other side is that there isn't any appreciable loss either, so it's break even. The et wasn't intended for sale anyways as it takes way too much work to build one. It was just to satisfy my own curiosity.
Yes, I'm considering longer runners and also a larger plenum using the et as a test bed for further experiments. This stuff is as addictive as crack. You're always asking yourself... well, what else can I do?
Old 08-18-2013, 03:11 PM   #12
That bone stock dyno chart is not your car, correct? There will be natural variation in that number (note the 93 degree temps for example, warm day!) You've been a big proponent of posting charts for the same car, under the same conditions, on the same dyno, which are awesome when someone bothers to do it, as you have.
The before and after tooter dynos were especially helpful.
Tooter, how did you get the car to rev to 6500? I thought stock rev limit (as shown on the stock dyno) was 6250.
I'm also not sure the difference between SAE and STD smoothing -- anyone know?
Old 08-18-2013, 05:31 PM   #13
mario98c
mario98c's Avatar
The stock rev limiter is 6,500rpm.
Old 08-26-2013, 03:13 AM   #14
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I would like to know how you have come to this conclusion? I wouldn't go totally off the tach that you are showing if that is your evidence. I have had several dyno runs and the software logging without a shadow of a doubt that 6250 is indeed where the stock ECU begins to force the AFR into a serious lean condition which is how Toyota actually "rev" limits as opposed to other methods.
Old 08-26-2013, 01:12 PM   #15
tooter
play every day
tooter's Avatar
The stock rev limiter on my 2012 cuts off at 6,600.
Old 08-23-2013, 04:34 AM   #16
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
I would also like to know about this.
Different Dyno?
Different Day(Humidity/Temp)?
Different Car?
Different Altitude?
Post 1375 is at HK MotorSports in CA
Post 1378 is at Keith's Pit Stop in PA
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 08-23-2013, 11:52 AM   #17
tooter
play every day
tooter's Avatar
Different Dyno?
Different Car?
Different Altitude?
I picked the other dyno run because it had higher results than this one, but since you asked, here's a stock dyno run from the same shop and the same dyno machine.
With the stock engine making 106 at the output shaft, 15 horsepower in drive train losses seems to be the norm.
I believe that the first two charts are of auto transmissions, so manual transmissions would naturally have less drivetrain losses. So you can spot them a few more horsepower if they were manuals.
Interestingly enough, we had the same issue with information dropping out on the graphs, but resolved it by grounding the chassis to a bolt in the concrete floor.
Here's another with intake and exhaust mods for comparison.
These are all posted in the dyno thread sticky in this section. It's an interesting read.
Old 08-25-2013, 11:37 PM   #18
tooter
play every day
tooter's Avatar
Another tooter rolled off the assembly line...
It's available on ebay for $545 with free shipping.
The tooter Build Your Own Intake Manifold Kits are also available on ebay for $295 with free shipping...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
