![]() Drives: Yaris sedan 2007 Join Date: Jun 2012
LOW RPM @Idle speed = Bad Volt Generation?
Hi, I am having troubles with Bat charging. I have 2 weeks driving with 10.8 to 11.5 volts (~70-80% Battery level). I chech my alternator and its working rarely, in some times at low rpm lights start blinking (high ripple voltage). But also, I have noticed Low RPM when car is at idle speed (~400 - 600rpm) are this normal? Anyone knows what is the minimun rpm alternator, to supply 13.8V? Thanks, /jp
I think an alternator pretty much put out 13-14 v even at idle.
Can you have your battery tested under load at a shop?
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2012
Id try and get your battery tested, I think i saw something saying Auto Zone does free battery testing.
Hi All,
I applied the Batt's Garantee, but still with my doubt. I'll have to wait time to probe this, because I have no time to do more testing. Check this: -At iddle speed, voltage on batt terminal is 13.5 (same value adding A/A and lights) -At 2000-5000 rpm, voltage ups to 13.7 Anyone have anysimilar conditions?.m Are this paramethers inside normal operation? My alternator is a NM toyota Denso. thanks any RE: /jp |
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
Your alternator output is a bit low, try replacing with a new battery and check your ground connections, if that doesnt help replace alternator.
| Tags |
| alternator, battery, low revs |
| Low RPM when Idle | Betrivent | DIY / Maintenance / Service | 12 | 03-03-2013 06:55 PM |
| driving on Low RPM | henry33 | DIY / Maintenance / Service | 25 | 09-09-2010 12:59 PM |
| Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. | dtbrown | Performance Modifications | 13 | 03-29-2009 04:35 PM |
| Yaris is low enough stock....trd springs bad??? | Yawesh | General Yaris / Vitz Discussion | 13 | 12-26-2008 12:17 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
