![]() Drives: 2008 Toyota Yaris Sedan Join Date: Mar 2012
In need of help with fixing dash
I have attached pictures of my dash. It has turned a gray color and I can't figure out how to fix it. If I am unable to fix it what are the part numbers? As shown in the pictures the black piece has changed color and also the plastic piece where the gas and speed is shown has changed color has well. If anyone is able to help me fix this or give me the part numbers please let me know. Thanks.
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I have the same problem!!!
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
I been trying to look up the name of both the pieces but I can't seem to find it
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
The cluster looks like it has condensation.. and then the flat piece looks like it's got some sort of discolouration.. I'm betting from the condensation. I'd say check your HVAC system?
I think it is there since I pouissh a cleaning thing on it....probably condensation but it does not look like it....
The lens for the instrument cluster is:
83852-52E40 (no tach) 83852-52R60 (with tach) The black trim piece is: 55411-52210-B0
Thank you CTScott!
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
That happens with certain cleaners, like Armor All. Mine did it as well. I used some Mothers Plastic Polish on a dry terry cloth rag and it came right off. Did a second coat just to be sure.
Probably a lot cheaper than ordering a new cluster lens. -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#9 | |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
theres even pics floating around somewhere on yw of a flyer from toyota saying to use pledge to better preserve dash pieces!
lol okay |
I'm gonna try using lemon Pledge to see if it comes off. I'm glad I already got some. Thanks for the help. I will let you know if it works for me. Can I use Pledge on the lens too?
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
From what I was told, you can use Pledge on the lense. You've got nothing to lose at this point, so try it and tell us how it comes out.
The Pledge didn't work at all.
oh no im sorry, i meant pledge would have been a better thing to use from the start... it probably wont remove that stain...
if i had the splotch problem in the second picture, i'd try the Rit Dye process to see if that would work.. but thats up to you! http://www.yarisworld.com/forums/showthread.php?t=16160 it looks like on the lense that its condensation on the inside of it. so if you can remove the dash piece and get behind the lense,maybe you just have to wipe the inside of the lense with mildew remover. good luck! sorry for the confusion
lol okay |
#14 | |
Pirate Yaaaaris
I can almost guarantee it was Armor All or something similar with shine additives that aren't suppose to come in contact with clear plastic. That's why they tell you not to get Armor All on your windows. If you scratch at it with your nail, you should be able to feel the difference between the cloudy part of the cluster, and the unaffected clear part near the top. A plastic polish and some elbow grease should get it off just fine; however, the longer you wait, the harder it will be to get it off. -C
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Toyota Silver Dash Kit | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 72 | 04-13-2012 01:42 AM |
| Remove dash cup holders and vents? | Shinare | DIY / Maintenance / Service | 3 | 08-03-2011 11:07 AM |
| Trade upgraded radio and dash for base radio and dash??? | Yarisguy13 | Items for Sale by private party | 4 | 09-17-2007 06:32 PM |
| dash problems...help needed | foggy08 | DIY / Maintenance / Service | 1 | 01-25-2007 08:04 PM |
