![]() Drives: VIOS (FL, 06 model) Join Date: May 2012
Thanks CTScoot, I will try it out.
Btw, I thought I saw 2 x White/Blue wires on the ignition switch connector (extreme left and right) ? Need to open the steering column to confirm again. |
OK - I see that. Pin #1 is the constant power feed (and is also white/blue). You want the wire in pin #3, which is ACC. The connector has six pins, so 1 and 3 are on opposite sides, like you said. ACC (pin3) is the one that has a black/red wire beneath it (pin 6).
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 05:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 09:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 03:12 AM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 01:51 AM |
| HELP! I detailed my interior, and now having a headlight issue! | Astroman | DIY / Maintenance / Service | 4 | 06-08-2010 07:51 PM |
