Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 06-30-2012, 03:10 AM   #2611
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Warranty mo sa electrical will be VOID when you alter or install 3rd party alarm system and/or lights kaya it is your call kung need mo warranty keep it stock kung gusto mo bihisan forget about warranty
Originally Posted by veranz View Post
hindi ko gaano kabisado ung batha from pinoy supermarket ba malapit na un?? pano ung waranty ng car kaya kasi 1 month p lang sa akin ung kotse eh.. di ba mawawala warranty nun?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-30-2012, 04:28 AM   #2612
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Well said by mr.Charliexx.....
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 07-05-2012, 03:37 AM   #2613
d"A"
d"A"'s Avatar
Drives: Yaris Y 2012
Mga sir ask lang po magkano mag palagay ng plastic para sa flooring?? And may recomended ba kayo na shop sa Ghurabi Area?
d"A" is offline   Reply With Quote
Old 07-08-2012, 02:18 AM   #2614
BoyMalambing
Saan kaya meron Steering wheel Adapter dito sa Riyadh yung universal para makabit ko sa ECHO ko. May nakita kasi ako sport steering wheel kaso wala silang tindang adapter... :(
Old 07-08-2012, 03:04 AM   #2615
charlieXX
Corporate Slave
charlieXX's Avatar
Tol ke Fort sa Ghurabi Manila plaza kaliwa then signal kanan mga 30 meters makikita mo siya sa gilid before nung malaking tindahan ng car accy.
200 paglagay ng plastic and all, ang TAGAL lang....baklas lahat ng bangko mo at make sure and INSIST na i-vacuum ng maigi yung sa akin baboy yung gumawa kaya lalong nagtagal at pinaulit ko, then may nakita ulit ako sa likod pinaulit ko ulit pusa hindi ko siya babayaran kung nagkataon eh
Old 07-08-2012, 07:44 AM   #2616
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
charlie, yung 200 tulad ba nung kay mike mc do yun na may rubber pa plus transparent na plastic?
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 07-10-2012, 09:04 AM   #2617
ronmainit
Drives: yaris 2008
sir, magtatanong po tungkol sa tire at rim, naka 205/40r/17 po ako 2 times npo akong nagpalit ng gulong sa front driver side kapag kinakabig ko ng full u-turn, dko alam saan tumatama eh sa loob ang butas nya po malapit sa rim na malamin mga 4inches ang haba, saan po kya tumatama yun, at advisable ba na palagyan ko nlng ng hub spacer un pra di na uli mabutas
ronmainit is offline   Reply With Quote
Old 07-10-2012, 09:27 AM   #2618
syntax
syntax's Avatar
sir welcome po sa YWME, sa katanungan nyo, pwede ba malaman ang offset ng rim?
Old 07-10-2012, 09:54 AM   #2619
charlieXX
Corporate Slave
charlieXX's Avatar
ah hindi plastic lang yung sa akin, yung ke Mike mcdo na may rubber eh sa kisame ata yun not on the flooring.
Old 07-12-2012, 07:55 AM   #2620
ronmainit
Drives: yaris 2008
sir syntax, check ko uli ung offset ng rim ko
Old 07-14-2012, 04:26 AM   #2621
charlieXX
Corporate Slave
charlieXX's Avatar
kamusta
Old 07-14-2012, 06:42 AM   #2622
syntax
syntax's Avatar
kamusta
Old 07-14-2012, 07:01 AM   #2623
charlieXX
Corporate Slave
charlieXX's Avatar
Syntax ok ba sigline ko.
Yan ang official sub group ng PINOY YARIS OWNERS SA MIDDLE EAST......TAKE NOTE NOT RIYADH PERO MIDDLE EAST as in GCC, Iraq, Iran, Syria, Yemen, Dubai, Jordan, Kuwait at iba pa
Old 07-14-2012, 02:56 PM   #2624
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
okay signature natin ah... pa forward naman charlie, thanks!
jonimac is offline   Reply With Quote
Old 07-14-2012, 03:58 PM   #2625
charlieXX
Corporate Slave
charlieXX's Avatar
tol email ko syo
Old 07-14-2012, 03:58 PM   #2626
charlieXX
Corporate Slave
charlieXX's Avatar
ano nga ba email mo joni he he he
Old 07-17-2012, 11:14 AM   #2627
JonathanHB2011
Drives: Yaris 2011 1.3L
amoy sunog
Mga kayaris ask ko lang po kung may nakaexperience rin ng pangangamoy sunog kapag nasa high RPM. pina check ko sa toyota service center di nmn ma-trace. Ang amoy e parang ung ginagamit sa pangkulot ng buhok....any idea mga kayaris? thanking u all in advance.
JonathanHB2011 is offline   Reply With Quote
Old 07-17-2012, 03:25 PM   #2628
charlieXX
Corporate Slave
charlieXX's Avatar
Hindi ba amoy clutch, baka naman naka babad ang clutch mo or baka mababa na ang pedal mo at may sabit ang clutch mo
