Old 07-18-2012, 10:17 PM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Nah i'll spill the beans :) The front springs will be either 400-450 lb/in and no front sway bar and rear springs at 350 lb/in. I could go higher but I think this is about the limit I want for a DD. I'll end up replacing my rear bilsteins with Konis or AST shocks and my bilsteins fronts are going to get revalved.
I've been trying to get dynatronics or pistani tune to give me a quote on getting the ecu flashed so no hassles with wiring but they do flash the ECU so that is at least an option.
I've been speaking to a coworker of mine about getting a long tube header made but also asking other companies about getting a header made for a reasonable price if neither of those two options works out or I decide to hit the easy button I'll likely have buy an off the shelf header.
I've been doing drawings about making a pillowball/camber plate since the upper strut mount from the prius is a close fit for the yaris but will need slight modification and a hole drilled but getting the plate made and the bearing cup welded is pretty simple plus if I could get the strut shaft slightly shorter I could turn it into an actual camber plate. But I may hit the easy button and buy the cusco mount if I want to spend an extra 200 dollars.
I've got a bunch of wire so I can move the battery to the trunk and it only adds something like 2lbs plus it gets rid of that stupid high battery in the front.
How many posts till ChinoCharles locks this thread? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 9 04-14-2009 05:54 AM
Reported posts ChinoCharles Suggestions - Feedback - Questions 10 09-25-2007 07:48 AM
