^ At $800 each (x2 !), they are pricey. Easier and cheaper to regrind camshafts here. We're doing a set for a customer now.
#2 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
+$1000 for cams seems REALLYdiculous for our lil 1.5... |
#3 | |
Now the hidden cost is that you may need to relieve the head to fit the 9.5mm cams, the taller lobes can hit the head casting. We have used a regrind before, works fine, and other than shimming the lifters you don't need to touch the head.
^ That's right the price did come down. I still say it's pricey compared to sending off a couple of cores for grinding, especially if the head doesn't need corresponding work.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
What about just getting MI to make a Head with +1 mm valves, a set of custom ground cams, and a port and polish? then it should be as simple as making sure the cams are clocked right, the head is torqued down to spec and the timing marks line up, then go go go.
^ just saying, if we ask enough they eventually will have to supply to the demand.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#6 | |
![]() Drives: Toyota yaris sedan Join Date: Apr 2013
Ok a friend was telling me that the scion xb 1st gen the exhaust camshaft have more duration the same valve lift but longer the time to close the valve. I am interested in jun cams but the thing that is keep me worried is the lift since the piston are a lill bit higher the valve could hit the pistons...
Thanks for posting again Nanoss!
Does anyone have specs on the cams? I did a quick search and couldn't find a FSM.
Yeah that will be usefull to know...
Fugitive
Drives: 2007 Yaris 4 Door Hatch Join Date: Jul 2014
![]() ![]() Drives: Vitz S 2007 LB Join Date: Feb 2013
any updates?
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Lotta work for very little HP. Me, I am shootin fer handling first, then play with braking. But, even the Blitz sounds better, and that too is a lotta dough for a little go
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I've been running the Prius pistons for a while now, cero problems
Next step is getting a emanage and tune it with something other than 93 octane for Track Days only
I Drive a 129whp Yaris ;) |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Prius Pistons + port & polish head where 18whp, and its a fact not an opinion cause the car was dynoed before an after (Y)
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
YarisPR who did your port and polish?
R-CaT Project Yar 2ZR |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
Angelo still lives lol
HacKers WanTed!
Lets meet up in Puerto Rico... lets do that soon...
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 08:38 PM |
| Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> | jay cobbs | General Yaris / Vitz Discussion | 8 | 06-07-2012 01:44 PM |
| SEDAN LOVE CHILD OF CAMRY& PRIUS | jay cobbs | Fuel Economy Forum | 0 | 05-23-2012 12:42 PM |
| Toyota says don't call them Priuses -- call 'em the Prii | Kal-El | Off-topic / Other Cars / Everything else Discussions | 7 | 02-22-2011 10:30 AM |
