Old 04-10-2013, 03:03 PM   #17
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
What about just getting MI to make a Head with +1 mm valves, a set of custom ground cams, and a port and polish? then it should be as simple as making sure the cams are clocked right, the head is torqued down to spec and the timing marks line up, then go go go.
^ just saying, if we ask enough they eventually will have to supply to the demand.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
