#91 |
![]() Drives: Toyota Yaris S 2011 Join Date: Jul 2015
Part number
I know the post is old but I would like to know the prius piston part number. Some stupid online sellers think the 1nzfe pistons and 1nzfxe pistons are the same. There are a lot of racers doing this mod in PR. But I wanna make sure I purchase the right piston. I don't wanna end up with the same piston I have. Please help.
#92 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Go back a few pages and read..........part numbers are posted.
![]() 2009 Toyota Yaris (Little toy) 2002 Audi A4 Avant Quattro 3.0L (Big boy toy) 1998 Subaru Legacy GT 2.5 (winter & DD) Last edited by Rigaud; 12-26-2015 at 01:19 PM. |
#93 |
Thanks
#94 |
Can these pistons be run safely without an engine management on 94octane gas?
Obviously you wouldn't maximize the potential unless you had at least a piggyback ecu but i'm curious if the stock ecu can handle the increased compression if you run the appropriate octane gas?
#95 |
0-60 in slow
Don't waste your time if you're running stock cams, the static compression ratio is so high that you'll be fighting detonation at low rpms. For these cams to really work you'll need some pretty aggressive cams.
2014 BSpec Divisional Champion |
#96 |
hmmm
#97 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I'am rnning the prius pistons, with 93oct and greddy emanage ultimate
I Drive a 129whp Yaris ;) |
#98 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
I'm already running 1NZFXE pistons on 93oct ...
but haven't updated my cams to 1NZFE yet.
#99 | |
#100 |
![]() Drives: Blue hatchback 2 door 2008 yar Join Date: Sep 2016
Do you know if those pistons would work on a 2nz-fe?
Thankss |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 08:38 PM |
| Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> | jay cobbs | General Yaris / Vitz Discussion | 8 | 06-07-2012 01:44 PM |
| SEDAN LOVE CHILD OF CAMRY& PRIUS | jay cobbs | Fuel Economy Forum | 0 | 05-23-2012 12:42 PM |
| Toyota says don't call them Priuses -- call 'em the Prii | Kal-El | Off-topic / Other Cars / Everything else Discussions | 7 | 02-22-2011 10:30 AM |
