Old 07-30-2012, 01:23 AM   #1
sawadee2you
Drives: yaris 2912
Need help on 16x8'' rims on yaris 2011
Hi, i am planning to get this rims on size F16x8'' offset 30 and R16x9 offset 15. My ??? is will it fit nicely on yaris ? 2nd,and if i am going to lower by 1.5'' will it hit the fender ? And my last ??? is what tire size should i get ?
sawadee2you is offline   Reply With Quote
Old 07-30-2012, 10:39 AM   #2
vten
the front should be okay if you add the camber bolt, the rear is a little tricky. I think you can add the EZ shim, camber it 2* and you'll be fine. Im using 17x8.25 +25 all around and since I have the rear disc conversion, can't add that ez shim , so my rear wheels are poke out a little.
http://www.yarisworld.com/forums/showthread.php?t=40482
Old 07-30-2012, 12:37 PM   #3
sawadee2you
Drives: yaris 2912
Thanks for advice,another pros here can advice me
Old 07-30-2012, 04:17 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
I'm running 15x9 on the rear with 205/50 tires lowered about 3" and only rub with full tank of gas and 3 people in the car . Also have about -3 camber shims in the back. You'll need to run 195 wide tires max with the low offset
Old 07-31-2012, 01:38 AM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
^ must post pic of 15x9 on car! NOW!
Old 08-01-2012, 12:49 AM   #6
blacksandiegovitz
Drives: 08 Vitz
Lol , type "brand new window visors " in the search and I have picture from a few months ago posted
Old 08-01-2012, 02:40 AM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks! Wow. They fit good!
8 Questions About the 2011 Yaris 5 Door Liftback (HELP) Pacquiao General Yaris / Vitz Discussion 5 06-09-2011 03:30 PM
New Toyota Yaris 2011 Spy Photos !!! orheen General Yaris / Vitz Discussion 35 11-24-2009 09:08 PM
