Old 08-09-2012, 09:26 PM   #11
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
Guys and Gals,
This really quite simple.I have seen eyelids for the sedans,I believe they do
not cover the top of the head-light surround the way I would like them too.
Anyone who has read my posts should know I have messing with cars for 35 years,paint work,restoration,cosmetic modifications,etc.
A good portion of todays cosmetic mods are simple peel and stick if you will,
another persons idea...
I strive( and always did)to come up with my own ideas,(you would be surprised what you can do with lead filling,plastic body filling etc)...
I admire George Barris,among others for their visions of customized vehicles.
What I did with my head-lights and tail-lights you can do also.In order to do this you first need the attitude,Do I want my car to look like anybody else's?
This is what I did,I purchased pin-strip tape and made my own designs on the headlights,then I masked off areas that I did not want painted,then I
simply painted the lights,peeled off the tape to see if I liked the results.
If I didn't fine I removed the paint with laquer thinner.
When I finally found what I wanted I sanded the headlight with 1500 paper so the paint would adhere used pin-stripe tape for the design,masked,cleaned the area to be painted and painted the base color
then cleared.
Then I thought about the tail-lights,they sure look hideous on the 12's
I saw that some were available for 500-600 bucks.I choose not to spend a
nice chunk of change on something that someone else might purchased,so I did the same thing for my tail-lights and saved about 450-550 bucks...
So far this is the only blue-lagoon mica Yaris I have seen...
I really do not want to capitalize on this,I would like to see people come up with your own ideas.
Dare to be different,use your imagination...
12 yaris is offline   Reply With Quote
