![]() Drives: yaris Join Date: Aug 2012
Scott,
I obtained a multi-meter before you posted this test procedure and what I did was use the 20k scale. I probed the yellow plug with the connector disconnected and just probed the male pins right inside the connector that is part of the clock spring housing. On each of them I would get no resistance on three pins but around 1.5 ohms on one of them. When I did the yellow wire on the orange squib connector I got no resistance on three of them and 4.5 ohms on one pin. Was my procedure and results valid in any way or should I redo it following your outline. Much appreciation for all your help! |
#2 | |
| Airbag light won't turn off | dubgil | DIY / Maintenance / Service | 128 | 08-03-2016 02:12 PM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 13 | 06-23-2013 05:39 PM |
| Replace airbag in my 2007 Yaris | uglyducklin | DIY / Maintenance / Service | 2 | 01-12-2011 03:53 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar | opdmize | Willing to Buy by private party | 1 | 03-19-2010 02:01 AM |
