Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Europe (continental)
Old 09-01-2012, 02:34 PM   #7
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
OK, heres thescoop:
Since we started the discussion, I got enough motivation to jump in and try the installation of a diode to the 12v Constant supply wire. I had considered a switch or diode and went with the diode to have less hassles in the future. I cut the constant supply feed line and soldered in a small rectifier (3 amp) and heat shrinked insulation on it. Installed the radio, and all the presets still were intact. removed the battery and serviced both ground and positive terminals which took about 20 minutes. Waited about another 15 minutes and re-connected the battery terminals. The head unit's presets were still intact! I am sure there is a cap in the head unit that keeps the volatile memory alive during periods of disconnection. I cannot understand why Scion had not intalled a 75 cent rectifier in the harness to make life so much easier for it's buyers! If the Yaris has no facility for this, an installed cap and diode would surely do the trick! All is now good, and thanks CT- for kicking me over the edge to do the mod! The Band side (Cathode) goes to the HU and the other end to the wiring harness.
bobolinko is offline   Reply With Quote
HELP, CAR SUDDENLY GOT LEAN Faraz_Shaikh Forced Induction Forum 26 03-31-2011 09:54 PM
HELP, my car is completely DEAD!!! Arlyarlz General Yaris / Vitz Discussion 18 07-19-2009 05:03 AM
3rd 360 dead, do I move to PS3 ? Dbeau Off-topic / Other Cars / Everything else Discussions 18 04-27-2009 10:04 AM
aftermarket dead pedal dtappe4926 General Yaris / Vitz Discussion 12 03-19-2009 02:38 AM
