Old 09-25-2012, 11:26 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Hmm, mine wouldn't fit that way. There wasn't enough length on the bolt for it to go through the bracket, flange, and L shaped bracket. I ended up using a spare flange on the compressor, bolted the bracket to that with some stuff I had lying around, then zip tied the dipstick to the bracket.
I'm now at this point where I believe I just need a longer hose to get the hose you can see in the top of the image onto the nipple at the bottom. I saw where you mentioned needing a piece of hose, so I'm guessing this is where.
This is what it currently looks like. I've noticed my top compressor tube thing has a kinda ugly weld seam that most people don't seem to have.
Old 09-26-2012, 07:54 AM   #2
Every one I've seen has that weld. Some people have custom finished that piece and have ground the weld down. Maybe that is what you are visualizing.
http://www.yarisworld.com/forums/sho...9&postcount=40
Here is a link to another install where you can see the weld is as pronounced as yours.
http://www.yarisworld.com/forums/sho...5&postcount=79
Yet another Blitz Supercharger Install CTScott DIY / Maintenance / Service 81 08-24-2025 03:30 AM
Blitz SuperCharger Install PETERPOOP Forced Induction Forum 127 09-23-2010 01:25 AM
an other blitz install thanks to Garm s3r3nity Forced Induction Forum 18 05-13-2009 09:35 AM
Amp install under the passenger seat questions.. MudBug In Car Entertainment + Electronics (audio / video / alarm) 19 06-06-2007 11:12 AM
