Originally Posted by _S7V7N_
Do you plan on adding another sub ?
Here's an idea. Get a 4 channel amp.
Upgrade your front speakers. Possibly with a component set.
Use channels 1 and 2 for your component set.
Use channel 3 and 4 for the subwoofer.
If you don't plan on adding a sub later on go with a custom ported box. You can probably get a plan (blue print) for about 5 bucks. They'll be able to plug the specs into a program. Then get somebody locally to build the box.
If you go sealed go with a bigger box and polyfil it. ( stuff used in pillows)
Though i havent ruled it out, i don't plan on adding another sub yet, i want to see what it sounds like first and then decide if i need another sub.
i do plan on getting another amp though, as i plan to use one amp to power the sub(s) and one for the speakers.
