Old 10-06-2012, 03:07 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
That would be a more fun project than the one I had to do 20+ years ago using a Motorola HC6811 microcontroller. My professor owned a lumber mill and our project was to simulate a control system (with PID control of the heating) for his lumber kiln using a toaster oven. We spent many late evenings in the lab writing code, drinking beer, and precisely cooking frozen pizza.
The project used to be an open-ended "you choose it, you build it" paradigm, but some students were getting in WAY over their heads and not passing the course, while others were making something far too simple and walking away with an A. The solution last year? "Here's a list of common hand-held electronic device functions. Choose three. Go." The net result was things like audio playback with accelerometer response and short audio recording, etc. The solution this year? "Build an Arduino-based RC hovercraft for < $100. Go."
What family of micros do they have you working with?
We start off with a Spartan3E FPGA, then move up to ATMEL Atmega644 and/or Arduino Uno. I'm trying to also use a PICAXE M2 in our controller, since they're cheap, low-power and super small (DIP-8 with 6 I/O pins!). What did you use for this little beasty?
Old 10-06-2012, 04:56 PM   #2
[QUOTE}What family of micros do they have you working with?
We start off with a Spartan3E FPGA, then move up to ATMEL Atmega644 and/or Arduino Uno. I'm trying to also use a PICAXE M2 in our controller, since they're cheap, low-power and super small (DIP-8 with 6 I/O pins!). What did you use for this little beasty?[/QUOTE]
I used a PIC 18F series, as I needed the extra processing power. I exclusively work with PICs, since that is also what I use for work projects.
Tags
calibrate, speedometer, tach, tachometer
Speedometer calibration Stiv DIY / Maintenance / Service 2 04-20-2020 09:54 PM
Speedometer Accuracy? YarisPete DIY / Maintenance / Service 37 11-29-2013 03:00 PM
OEM Speedometer with tachomter Deshi Basara DIY / Maintenance / Service 6 08-21-2012 11:11 PM
speedometer walt101786 Cosmetic Modifications (Exterior/Interior) 0 10-09-2010 10:03 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 11:38 AM
