#37 |
Okay i found the pics so everything is relinked and back up now.
#38 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Hey, Thanks for the write up. Just did it yesterday and you're right, the braking is entirely better.
#39 |
![]() Drives: 2008 Polar White Yaris Sedan Join Date: Mar 2010
i just had a 27 point inspection or something at a toyota dealer
they told me my rear brakes were out of alignment, and explained it like my brakes were not expanding enough to grab the sides of a bowl or something... is this what i need to do to fix that? |
#40 |
Free Mustache Rides
HELP HELP HELP. in middle of doing this, only have 30 mins til i gotta be somewhere. i CAN NOT get off the brake drum. i see im slightly bending the backing plate when i try the screw driver method. any help??!!?
#41 |
^I guess it's too late but... 1. Parking brakes off. 2. Whack it with hammer or mallet a few times. or.. 3. do the appropriate bolt size into the hole to force it off that way.
I just whack it with a hammer.
#42 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
Best way is using the bolts to ease it off 10 MM if I remember correct. I bent the crap out of my backing plate before trying the bolts.
#43 |
Free Mustache Rides
thanks for clarifying the size of the bolts, i had a box of screws (including wood screws-i got desperate) but didn't have the right size and gave up. i tried to go through the rubber plug that everyone suggested not to go through (once again, desperate) but i had no idea what i was doing. guess ill go to hardware store, pick up 2 10mm bolts and try again next weekend. thank you
#44 |
arent these brakes self adjusting? Dont they adjust when you back up? Or doesnt that setup work after a while?
#45 |
Yes, they adjust as you back up. The adjustment allows you to apply the same amount of distance in the foot. The problem lies in the the cable/hand brake. I don't know the reason for this but you still have to adjust it every-so often in order to tighten that up. It is important to note that you should adjust at the brakes first, then see about tightening at the base of the hand brake.
#46 |
![]() Drives: 2014 yaris hybrid Join Date: Nov 2010
Thanks YarisSedan, I am soon going to be replacing my shoes which have 135,000kms on them. Knowledge sharing is appreciated.
Okay, did my oil & filter change this evening and checked the drums while I was at it........... new shoes have 4.6mm of braking material and the shoes after 135,000kms have 3.6mm of brake material left. So I'll leave them in for another 1mm of wear I reckon. Last edited by 746watts; 02-27-2011 at 05:41 PM. Reason: had a look |
#47 |
![]() ![]() Drives: none Join Date: Feb 2012
Sorry for the bump. But OP can you please relink the pics? Thanks
#48 |
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Ok, I am not seeing these pics.
Is it just me or are they gone? If they are gone from this thread does anybody have them? Thanks. |
#49 |
Sorry guys the account I used for Web hosting closed so some pictures are lost I have to adjust my rear brakes again soon so ill try to put some new pics up and put them on photo bucket with a link
#50 |
^Thanks.
Been wanting to do this. cheers |
#51 |
I had both on my car done about 23k miles ago (so I probably won't need to again for quite a while) and I paid only a little bit less than Jamal1984 did. The pictures will help more than a few people whenever you are able to get pics to display and all will appreciate your gesture.
#52 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Yes,if someone could repost the pics, that would be a great help.So, you adjust the drum first,then adjust the parking brake?.Now the adjustment for the parking brake lever.....is this a different procedure? or is the lever adjusted when the drum brakes are adjusted/taken-up?.
#53 | |
#54 |
Tw200--excellent!
| Rotated tires and adjusted rear brakes today PICS | auxmike | DIY / Maintenance / Service | 11 | 11-14-2008 08:24 AM |
| DIY: Painting Factory Brake Calipers | redyaris | DIY / Maintenance / Service | 38 | 05-26-2007 08:47 AM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
