Old 10-22-2012, 07:44 PM   #16
nookandcrannycar
Originally Posted by alpha1 View Post
Many factors for break wear. For the yaris, one of the most obvious is the weight of the vehicle vs. a heavy vehicle like a truck... expect the breaks to last longer on lighter vehicles....
& also the tires with less friction due to less weight will result in less wear = more miles before replacement is needed if using the same tire rubber material.
I just purchased a yaris & like seeing the length of time/mileage you obtained prior to servicing the items mentioned.
Another family car is the Pontiac Vibe = Matrix twin and it has over 70,000 miles without servicing brakes. The oem tires went 50,000 miles before replacing.
My brakes were only 20% worn at around 208,000 miles. Yarisworld member trini_per4mance didn't have to get his first brake job until 400,000 miles. I replaced the OEM tires between 69-70,000 miles, the first replacement set of 4 at 140,553 miles and the second replacement set of 4 at 225,562 miles. Each set has exceeded the mileage rating (I think each set was rated at 60k, but one might have been 65k).
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Summer tires ! Franck_Qc Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-02-2009 09:36 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
