Old 10-28-2012, 03:47 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
the first switch had both resistors removed from the lights, the second switch only had the constant on light disabled. both switches when engaged would light p the fog light indicator on the instrument panel. before the last one went out the switch light came on but the dash didn't nor did the fog lights themselves. when it did the i turned it off and back on and the switch on indicator light in the switch flickered and went out.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
LF: Yaris switches carrera2 Willing to Buy by private party 0 07-11-2009 05:10 AM
Power Window Switches Stoln Australia 5 11-07-2008 09:02 AM
