![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
Paint....
My Yaris had been in a small accident before I bought it, and because of this whoever repainted the bumper didn't do it right.
March ![]() November ![]() 30 minutes with a garden hose ![]() Good news, It's only $300 to have my body guy paint it up right. Looks like whoever did it first didn't do much prep work at all....I also don't have my S front lip. |
Not quite a noob
Looks like they didn't clean it at all before painting.
Not quite a noob
Actually, they didn't even prime it
Well, with plastic you shouldn't really have to "prime" it, but it needs some sort of surface treatment for the paint to stick. Usually some sort of sanding coupled with an adhesive....none of that was done. It was simply sprayed and left on there.
Not quite a noob
You need to prime plastic. You'd use an epoxy primer so that the primer sticks to the plastic, and then the primer itself is sanded to create mechanical adhesion for the paint to stick to.
At least the paint was matched pretty well, though.
![]() Drives: Polar White 4 Dr Join Date: Jan 2007
it probably will cost more to get Yaris S front lip and color matched.
2007 Yaris Base Sedan |
![]() Drives: 2008 Yaris HB Join Date: Jul 2011
I paint for a living and that's clearly a lack of a plastic adhesion promoter step in the refinish process. Sometimes I'll get cars like this in my shop and we just blow off all the paint with a high pressure air hose.... and then repair it correctly
#yyc
Drives: BSP '07 RS 5dr LB Join Date: Aug 2011
Just hit up your local home improvement store for a lip. :p
Form>Function
Wait did they steal your lip or are you just trying to find one? I have an s lip sitting in my garage that I got slightly used for 75. No cracks or broken tabs its just painted black. I haven't decided whether I'm gonna use it yet. Right now my place of residence has too many large speed bumps and I'm already 2.8" off the ground. But I got mine at a salvage yard. Check there too.
And doesn't all Toyota paint look like yours lol |
All better!
The lip is going on in a 2nd appointment. ![]() ![]()
![]() ![]() Drives: Want a yaris Join Date: May 2012
Unfortunately this happens a lot with car repairs. It only has to last until someone else owns it. Glad you got it taken care of and looking good. I bet it really got under your skin at first though!
Lip installed!
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
much better
#17 | |
#CarFiend-HANZO188
Drives: 2011 Toyota Vios Join Date: Oct 2012
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Stripping Paint Without Sanding | CrystalJean | DIY / Maintenance / Service | 1 | 10-06-2012 04:06 PM |
| New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
| Questions about interior color and exterior paint | wiirenet | General Yaris / Vitz Discussion | 5 | 03-01-2009 06:28 PM |
