![]() Drives: YARIS Join Date: Nov 2012
I found where are that fuses but if i remmber i check both of them and are ok.
I will check again but if they are ok what other reason can be? Thank you. BR. |
It could be something like what Ray (1NZYaris) said above, where the system is in an incorrect state. You could try disconnecting the battery for a couple of minutes to reset the Body ECU, which controls the door lock functions.
Hi.
I didnt solve yet door lock-unlock problem. Please if you can explain to me what fuses are responsable for good work of door look system. And if is posibile to found some diagram to check actuators from doors and hatch. After measuremnt i found an yelow wire in connector for doors in left side where resistance must be under 1 ohm but is around 8 ohms and i supose comparing with other diagrams this wire is comand driver door actuator and is not looking well. Thank you. BR. |
| 2012 Yaris SE Stuff | computerlove87 | Willing to Buy by private party | 0 | 11-25-2011 02:06 PM |
| '54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem | Lettuce | UK | 0 | 09-30-2010 06:21 AM |
