Old 11-27-2012, 12:33 PM   #13
david_827
Drives: 07 Yaris Sedan
You have to track them down via a junkyard. I have right hand drive and left hand drive versions of the digital cluster that I purchased from junk yards in Australia (RHD) and Israel (LHD). They work fine in a US Yaris with the exception of having to extend the cables to the cluster for using one with the opposite side drive. You wouldn't want to do that though, as the display is angled to point towards the driver.
As for the electronic climate controls, that requires quite a bit more work. I actually successfully did so, but it requires also changing some wiring, the AC ECU, and the manual flap controls. Here's a video of my conversion while I was working on it:
http://www.youtube.com/watch?v=qbInNKKEwFc
Do you by chance have the names, or the links to the israel ones?
david_827 is offline   Reply With Quote
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
