#145 | |
play every day
A 4-2-1 tri Y header pairs up sequentially firing cylinders 2-1 and 3-4 so that the exhaust pulse from one helps to draw exhaust from the other. ![]() ![]() Then the combined 2-1 and 3-4 pairs join to help scavange each other... ![]() Practically speaking, the headers are too short to make a lot of difference. But that's where namer comes in...
#146 |
Form>Function
The 4-1 is supposed to delay the power increase until higher in the powerband. The 4-2-1 is supposed to give a midrange bump. On our tiny cars you probably would never notice a difference. I love my DC header. Anytime I'm above 4k I'm just roaring and pulling hard for a yaris lol.
#147 |
play every day
I actually did notice a difference...
...as I climb a steep 1/4 mile hill in 2nd gear to get to my house. It's always the same hill, so that's constant. And driving up it everyday I have a good feeling for the resistance. The header definitely helped the engine make it up the hill easier. If you start climbing under 2,000 rpm, the engine labors sluggishly. But anything over 2,000 and it gains rpms much easier and climbs more easily than the stock header which feels like it's holding back at the same rpms. |
#148 |
^ An aftermarket header will certainly make a difference over stock, but I doubt you can feel any difference BETWEEN aftermarket headers. You just can't feel 1-2 horsepower, in my opinion.
#149 |
TRYaris is that your car in your avatar?
#150 |
0-60 in slow
Basically what Cali said.
There is a maximum of about 12" to work with and an ideal length of about 35" so most of the ots headers compensate by increasing the volume of tube which in essence give some of the same effect as increasing length but reduces scavenging at lower rpms. Now this motor is relatively small displacement with a good torque management system going to a larger diameter tube won't hurt you as bad as it would on a larger engine. So not wanting to give up anywhere in the powerband while still gaining some up top is the reason I decided to design and build my own header. As far as header type is concerned both a 4-2-1 and a 4-1 will accomplish the same goal but each design has its own advantages but both of them can produce near the same power and torque so there isn't a real advantage to choosing either one aside from packaging constraints, and a 4-1 is simply easier to package with the effecting lengths required. |
#151 |
![]() ![]() Drives: Racin' yaris :D Join Date: Nov 2012
#152 | |
Form>Function
Tr that pic I think is sporting a MI Hood visor. |
#153 |
play every day
That's one thing I really like about the Weapon R. It's precise. You could cut your finger on that sharp knife edge where the two main tubes are joined...
![]() But as far as performance, it doesn't matter.
#154 |
0-60 in slow
That's not a good thing, air doesn't like sharp edges.
#155 |
I don't think it would make that much of a difference in our case either way.
![]() Any aftermarket header should prove to be at least slightly better than stock, right?
#156 |
0-60 in slow
the slight knock it causes in flow won't make much of a difference.
#157 |
play every day
#158 |
0-60 in slow
I wouldn't worry, all of the aftermarket headers lack a ventur,i so the collector looking bad wol make almost no difference.
#159 | |
play every day
The DC is a time tested design. And in my opinion, trailing edges don't matter. Those are the edges that point in the direction of the exhaust flow. |
#160 |
Form>Function
Tolmach yours also does not have the ceramic coating. I thought all DC headers for the yaris came coated.
Is it a replica? Poor build quality, alteration of branding, and lack of ceramic coating... sounds like a Rep. |
#161 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Tolmach, your pipes look kind of small as well but then again my Megan Racing header is 3mm larger diameter but i wouldn't think that i could tell the size difference in a picture with out side by side comparison.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#162 |
![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
Can someone measure the I.D. on one of the primaries on this header? It looks similar to the OEM and somewhat smaller than the Weapon R header.
