Originally Posted by brg88tx
lemme guess, your electrical problems started right after you replaced your failed water pump....riiiiight.
I hope someone else knows where this guy was going, since his post is 2 years old.... but I would answer YES to this question... that make a a difference?
I changed the pump, put everything back together, it started up nice n quiet now finally but:
Basically the only electrical devices that come on are the headlights. No tails, running lights, radio, heat n a/c, tire pressure light and P/S light are on. The battery light is NOT on so it is charging. Yes, I removed the alernator to do the job, of course, and NO I did not drop it or anything silly like that. This is the first time I I have ever had to work on this car.
If it makes a difference, I had to do this job after the water pump pully becoming so wobby it must have siezed for a decond and snapped the belt off at 75MPH.
Thanks for the help, anyone!
