Old 12-28-2012, 01:19 PM   #7
Originally Posted by baseballfan416 View Post
Thank you CTScott.
But wow, that sucks... tsb's only good for 60k? Such a simplistic car and yet so buggy... cel went off on it's own...
The TSB provides a simple Techstream procedure for verifying if the issue is the timing gear, or if it is the VVTI oil control valve. The OCV can easily be damaged during a belt change, and also it has a filter screen mounted below it that can get plugged over time.
Since you are over the TSB coverage period, I would start with either having someone try the test procedure with the TechStream tool, or with checking the OCV for damage and cleaning its filter screen.
Dreaded P0012 Code - What to do now? special_k_828 DIY / Maintenance / Service 17 07-11-2011 02:14 PM
