Old 01-12-2013, 09:57 AM   #11
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
VERY easy test. All you need is a volt meter. If the battery drops below 9V while cranking on your first start of the day, it's done.
On my Echo the factory security locks the doors as the key is turned to ON with all the doors closed and unlocks when the key is turned back off. Two years ago the doors stopped unlocking and it was because the battery was dropping to a point that the system would reset after locking the doors. I put in a good battery and the problem went away.
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
