Old 01-12-2013, 09:02 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
The two most common causes of failed catalytic converters are:
-engine burning oil. This causes too much fuel for the catalyst to react with, and it melts.
-vibration. Such as a broken exhaust support bracket, or even just a rattling heatshield.
It is also very common for inexpensive aftermarket cats to only last a year or two; Even in good conditions. They use the bare minimum of the expensive catalyst materials to meet OBDII requirements (and sometimes not even that).
Yes, over-fuelling can cause cats to fail (same reason as the oil), but newer cars are much less likely to over-fuel that much without throwing a code.
Do you notice any blue smoke from the tailpipe when starting it cold? Any buzzing or rattling noises from the exhaust?
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 01:23 AM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
