![]() ![]() Drives: 2008 2dr Yaris Liftback Join Date: Nov 2012
Assuming that your wheel has been covered up by a hubcap, its most likely accumulated a bit of dirt, grime, and rust over the past few years. You'll want to clean up that stuff to make your wheels a bit shinier. For instance:
+ =![]() That's from http://www.fjcruiserforums.com/forum...an-glossy.html My wheels didn't shine up nearly so nice, but it helped. Add trim rings to that and you've got hot looking wheels on the cheap. A more permanent solution is to spray paint them as BEEF did, which is for sure the better solution if you have the time. Here's BEEF's thread: http://www.yarisworld.com/forums/showthread.php?t=39500 |
| My trim rings and center caps..... | RedRide | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 11-05-2017 06:42 AM |
| Trim rings | Rikantank | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 07-17-2012 07:50 PM |
| A/C Vent Trim Rings | TinyGiant | Cosmetic Modifications (Exterior/Interior) | 25 | 06-19-2010 04:09 PM |
| TOYOTA center caps and Trim Rings for sale. | coffiend | Items for Sale by private party | 10 | 05-11-2010 06:29 PM |
| Good source for trim rings? | RedRide | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-08-2009 11:59 AM |
