Old 01-19-2013, 09:52 PM   #7
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Or, Mobil1 extended drain once per year @ $27. for 5 quarts.
And Denso oil filter twice per year @ $3.x2.
3k/3 month interval:
Conventional Oil 10w-30 (40qts needed for 25k miles)
@ $3.00/qt * 40 = $120.00
8 Standard Filters
@ 6.00/filter * 8 = 48.00
Total: $168.00
AMSOIL 25k/1 year interval:
AMSOIL 10w-30 (5 qts needed for 25k miles)
@ 7.35/qt * 5 = $47.75
1 EaO Filter
@ 18.30
Total: $55.05
Savings: $112.95 annually
Even if you only drive 12k miles per year you are saving just in oil/filter costs not to mention the following benefits:
- Easier cold-temp starting
- Improved fuel economy over time
- Cleaner running engine
- Cooler running temps
- Should experience more power/throttle response
- Less engine wear
- Longer intervals between changes which means less inconvenience of the car being at the shop
I wouldn't use a standard oil for more than 3k miles so if you are fixed on using conventional then yeah stick with 3k changes, but it is a monumental waste all around.
UberSilver is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
