Old 01-21-2013, 06:02 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
In normal driving it doesn't bog down like stock when you let out the clutch. and you can feel it come on stronger at around 3,000 rpm on up. The larger bore of the throttle body now better matches the increased flow abilities of the tooter. It feels lots more gutsy.
Now some of this effect is simply the fact that when you push on the gas pedal, the larger throttle body's butterfly is letting in more air for the same throttle position.
But the biggest difference is when the throttle is to the floor...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
