![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
anyone currently running two sets of camber bolts?
Hey all,
I ordered another set of Toyota OEM camber bolts today I plan on using two of them per strut (top and bottom hole) to maximize my neg camber..do you guys feel this is safe?
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
I have one set up front and its adjustable up to 3 degree together with oem adjustment .
I set it on 2.8 , for about 2 months daily driving about 250-300miles per week , my inside front tires are already show some wears ... Imagine them with 2 set, more negative camber , Unless you don't mind to spend some $$ changing some tires often, then go for it . |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
I have been running two sets the last last couple of years. But I am not using the stock bolts, I think its a mismatched set of Ingalls and SPC.
Our B-Spec car has two sets of the Toyota bolts, but it has seen so little actual use its hard to say how good they hold over time.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
So running two sets of the OEM ones should be safe on the street? If I use 2 sets per strut -3 is a realistic expectation
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
I have one set and my alignment shop said it maxed out at -1.15 I want more neg camber up front too
#6 | |
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-04-2013 at 03:26 PM. |
You cam always slot your top strut hole as well, I know this adds a ton of negative camber
#8 | |
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 02-05-2013 at 12:38 PM. |
#9 | |
Form>Function
Also I tried doing it myself but I didnt have enough hands to hold the spindle at a greater angle while tightening the bolt and haven't been able to find a buddy with time to help me. So until then all I can do is rant lol |
^ maybe it's time to cultivate more friendships.
![]() I'd come over, but I never get invited.
#11 | |
Form>Function
Idk how you feel about Tampa but if you're game then absolutely you're invited lol |
#12 | |
Form>Function
^ nice tip thanks. What do you need the lugs back on for? Or are you using the Jack to push the lug nuts which would move the spindle?
#14 |
The lugs keep the rotor from moving around inside the caliper, and prevents any threads from getting damaged on the wheel studs.
#15 |
Form>Function
Got it thanks.
Back to topic |
#16 |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
I'm running two sets of bolts :) I say go for it.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| adjustable camber bolts? | b20vteg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2012 10:08 AM |
| Adjustable Camber Bolts | Kendrik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 07-16-2012 04:05 PM |
| Adjustable Camber Bolts | cali yaris | Micro Image | 30 | 12-11-2009 09:38 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 12:19 AM |
