Old 02-20-2013, 07:02 AM   #21
HuchoTS
Drives: YarisTS,Corolla,Carina,Prius
Done it in less than 5 minutes on both sides.
1. pull the connector Off
2. pull the rubber boot off the bulb completely so you have the complete rubber boot off in your hand ( sometimes it sticks to the bulb due to heat. get your fingers as close to light bulb you can and pull the rubber off the back of light bulb) otherwise you can not release the spring that holds the bulb in reflector.
3. feel for two metal wire bumps (its a spring that holds the bulb in place) on each side and squeeze together (pinch style ;) ) to release the light bulb. The key is to move it in horizontal direction Don't push in or pull the spring. Just move it horizontally towards the light bulb.
4. replace the bulb and go step by step backwards . All Done!
HuchoTS is offline   Reply With Quote
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
How do i change license plate bulb? Centurion2200 DIY / Maintenance / Service 3 09-26-2006 09:01 AM
