Yes. Swapping the remote is easy. I wasn't sure from your picture if it or the outer case was the broken part.
![]() Drives: 2006 Yaris hatchback Join Date: Feb 2013
Ahh I understand what your saying now.
Thanks very much for your help and advice on this matter. I will update as to how I went in the next few days once I get the key cut. Thanks again! |
#3 | |
![]() Drives: 2006 New Zealand Model Join Date: Jul 2007
Purchased a blank key with remote shell online $15, then swapped remote keyless entry module / battery into the new key. Took it down to a key cutting shop and had it cut for $13. The shop told me I needed a transponder which he was correct, what most people do is have 2 sets of keys (which didn't make sense). The original key house was cracked and could barely turned the key in the ignition, so it made good sense to butcher it up to retrieve the transponder. Toyota used some epoxy like glue which proved to be difficult in getting the chip out - i'm sure many may have ruined the transponders by careless cutting. Had used hack saw and a sharp razor blade and small jewellery flat head screwdriver (for careful prying). You know Toyota could of easily made the chip removable as the chip fits snug enough into the new key. I guess Toyota dealers don't have the skill or want the risk of trying to extract the transponder chip out. Much easier and profitable to charge out for new key and programming. ![]()
![]() ![]() ![]() Drives: Yaris T-Sport Join Date: Nov 2016
Help with replacing 2 button key remote
I paid 170€/$ for the key and 20€/$ for programming ! Just remember not to ruin all black coloured keys ! That grey service key cannot be used when programming new keys !!
![]() ![]() Here in northern Europe keys are like this |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 06:32 PM |
| Lost key (transponder and remote lock/unlock) | shyeoh | DIY / Maintenance / Service | 4 | 07-11-2013 05:04 AM |
| Yaris 2012 Sedan Key with remote | faisalloe | General Yaris / Vitz Discussion | 5 | 09-27-2012 10:29 PM |
| Yaris 2007 remote entry doesn't open (it only closes) | nicorac | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-08-2011 11:02 AM |
| Need remote key | fraenx | DIY / Maintenance / Service | 1 | 06-26-2009 07:29 PM |
