Old 02-04-2013, 09:44 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
rebuilding front susp. parts.
has anyone replaced the stock stamped cheap A arms and hub and spindle with an aftermarket set up thats a bit more rugged ..on the 07 hatch..??
yaris9876 is offline   Reply With Quote
Old 02-23-2013, 08:33 AM   #2
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
Bump
I've looked around a bit for some aftermarket lower control arms but haven't found anything.
RUBBERDIPSTICK is offline   Reply With Quote
Old 03-01-2013, 06:32 PM   #3
Monstro
Drives: 2010 Black Yaris Lb
Moonface-Japan makes some, you can see them on rhdjapan.com
Monstro is offline   Reply With Quote
Old 03-01-2013, 09:47 PM   #4
racerb
Never replaced the entire assembly, but back in the old IMSA days the team I crewed for would always reinforce the stamped lower control arms. Basicly what they would do was remove all the bushings, lay the arm out on a 1/8" flat sheet of metal and outline the arm. After cutting these to fit, they'ed stitch weld the entire outer edge at about 1"-2" intervals. This made the arms very stiff and allowed the suspension tuning to stay adjusted all the way through it's range of motion. You should be able to do about the same with your control arms, just useing a plasma cutter and a good tig welder to put it all together.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
wtb silver yaris sedan FRONT driver door and front drvr fender Slitwrist Smile Willing to Buy by private party 2 04-01-2011 08:59 PM
What are these parts called? ammophobia DIY / Maintenance / Service 5 12-16-2010 11:04 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
Parting out 89 acura legend coupe performance, custom and oem parts for sale YarisSedan Items for Sale by private party 1 03-26-2009 10:06 PM
