Old 03-07-2013, 04:02 PM   #28
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I can almost guarantee you, you'd be doing more harm then good by swapping to otto cycle cams in your engine. The prius is mainly powered by the electric engine, so to make that as efficient as possible the torque output on the gas engine needs remain a constant. The numbers I listed were WAG and so probably not accurate. Remember your gas engine isn't directly connected to the wheels, so its RPM's are also not a contant
Here is a website that explains how the HSD powersplit device works. Website
Upping the power on the gas engine doesn't help as much as you'd think since only torque at certain rpms provides assist. Since the engine only revs to 5k you'll be throwing away all the constant torque of the fxe to gain the peak torque of the fe all with major loss and no benefits. You have to think of the gas engine as a electricity generator/backup power unit rather than a PU. You can rev the nuts off the Prius engine and the car won't move unless the electric motor is moving.
2010 Prius tuckevalastin Off-topic / Other Cars / Everything else Discussions 60 01-13-2009 12:24 PM
Stupid prius KSIbucky Tracking, Racing, Auto-X Forum 11 09-25-2007 11:07 PM
ZPIracing Turbo Pistons ZPIracing Forced Induction Forum 22 05-29-2007 03:39 PM
And You Thought the Prius Was Expensive! redyaris Off-topic / Other Cars / Everything else Discussions 5 05-18-2007 05:11 PM
Toyot Prius YamilR Photo-Video-Media Gallery 4 02-14-2007 06:54 PM
